Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Uncaught SyntaxError: Unexpected token ILLEGAL
i am getting this error
plz check my code below
where i am wrong?
thanks in advance
var playerInstance = jwplayer("myElement");
playerInstance.setup({
file: "https://player.vimeo.com/external/65287109.sd.mp4?s=16801a15e378578dc2e0b51d9a19a52c
width: "100%",
aspectratio: "16:9",
title: 'Video1 ',
autostart: true,
description: 'videochapter1',
playerInstance.on('time', function(event){
var elapsed = playerInstance.getPosition();
//document.getElementById("hms").innerHTML = elapsed;
var state = playerInstance.getState();
//document.getElementById("time").innerHTML = state;
var totalSec = parseInt(elapsed);
var hours = parseInt( totalSec / 3600 ) % 24;
var minutes = parseInt( totalSec / 60 ) % 60;
var seconds = totalSec % 60;
var result = (hours < 10 ? "0" + hours : hours) + ":" + (minutes < 10 ? "0" + minutes : minutes) + ":" + (seconds < 10 ? "0" + seconds : seconds);
var results = result;
document.getElementById("hms").innerHTML = result;
function loads(){
$.ajax({
type: "POST",
url: "save.php",
dataType:"json",
data: { 'dataString':elapsed},
success:function(response){
$("#time").html(response.timer);
//setTimeout(loads,100);
var str2= "00:00:05";
if(response.timer > str2 )
//alert("Time Out");
playerInstance.stop();
playerInstance.remove();
clearTimeout(loads);
document.getElementById("hms").innerHTML = '';
document.getElementById("time").innerHTML = '';
document.getElementById("myElement").innerHTML = "<span style='font-size:150px'>Time Out</span><br/><p>To View Full Video</p><br/><a href='member-profile.html'>Purchase</a>";
1 Community Answers
Randy
JW Player Support Agent
0 rated :
Hello,
If you add:
type: “hls”,
Does that work for you?
Randy
