Automatic stream quality selection in JW6 (vs. JW5)
Hi, I'm upgrading our app from JW5 to JW6 (Can't go to JW7 as we need IE7 & 8 support).
I can play videos fine, however it only plays the default stream quality, rather than automatically adapting to the best the user can manage (like it used to correctly for us in JW5), and the new 'HD' button does not include "Auto" as an option like I see in several live demos here.
I don't have a live code sample available for you to debug unfortunately (this is part of a large, paywalled app), but in setup() we used this for JW5:
levels: [
bitrate: 1200,
file: videoUrl.high
bitrate: 900,
file: videoUrl.med
bitrate: 600,
file: videoUrl.low
Where 'videoURL' is an object of our mp4 urls (unchanged from JW5's usage). For JW6 I've changed that to be:
sources: [
bitrate: 600,
label: 'low',
file: videoUrl.low
bitrate: 900,
label: 'medium',
file: videoUrl.med,
'default': true // In quotes because 'default' is a JS reserved word
bitrate: 1200,
label: 'high',
file: videoUrl.high
*What else do I need to be doing to enable automatic stream selection?*
(Apologies if this is answered in another question, I promise I searched. Also, the guide to migrating from JW5 to JW6 that's linked in many answers no longer appears to be available: http://support.jwplayer.com/customer/portal/articles/1404037-migrating-from-jw5-to-jw6)
