I am using jwPlayer 7.2.2 I want to show selected video quality label instead of HD button. For example if I select quality 720p then it show 720p on the place of HD button not HD.
This is my example link. http://granjur.com/jwplayer-7.2.2/
I am seeing the player’s File Not Found error on that page. I checked the source code of the page and it looks like the URLs of the videos are pointing to a different folder.
You could potentially try to achieve this with some form of CSS as our player interface fully supports this approach. You can find more detail here: http://support.jwplayer.com/customer/portal/articles/2067702-skin-css-classes-reference-.
