Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Mute mode does not work...
I set all parameters, and checked the "mute", but when I copy the java code and I insert it in my template, is not working.
Cow do I fix?
This is the code:
<script type="application/javascript" src="//content.jwplatform.com/players/uZ86Dk5H-dVuVV66k.js"></script>
This is my site:
www.vendingnews.it
The video is in the sidebar on the right.
Thanks!
3 Community Answers
Alex
JW Player Support Agent
1 rated :
Hi, there.
I took a look at your issue and it looks like our player is having trouble muting YouTube videos when the player is set to autostart. I am going to escalate this to our engineers and see what they say. As soon as I hear something back, I will let you know.
In the meantime, there are two workarounds:
1. Disable the autostart option on your player.
2. You can use our JavaScript API to mute the player once it begins playback. The following code should work:
jwplayer().on("play", function() {
  jwplayer().setVolume(0);
Thank you!
fabio.russo.napoli
User
0 rated :
Thank you for answering!
I must insert this code into the file function.php?
Alex
0 rated :
Hi, Fabio.
I have heard back from our Engineers and they have filed a bug report for this issue and will reach out to YouTube for assistance on this. Unfortunately, there are no timeframes on a resolution. You can keep an eye on our JW 7 Release Notes page as we post release notes and bug fixes with every new update.
Thank you!
