jwplayer HD button light enable for 720p video quality
Hi, I am using jwplayer 7.1.0 . I have multiple playback sources. HD button light on for every playback source. I just want to keep it on for 720p. How can i set configuration for HD button.
The player on that page is pointing to a source on your localhost. Please point the player to files on a web server and let me know so I can help you troubleshoot your issue.
What you are seeing is the HD button in the controlbar not being on, it is technically off if it is white. If you only had two sources, the button would light up red if it was on, but since there are more than two sources, it remains white but produces the menu overlay to let the viewer choose the quality.
I believe your issue is less with the color of the button, but the fact that it says “HD”, correct? If so, it is possible to change this, or any of our buttons, by using CSS and web fonts. Please see the following support articles for information on how to do this:
