Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
How to Eliminate Latency from the Player
Hi,
I'm trying to play a live rtmp stream from a Wowza server using JWPlayer (obviously) with as little latency as possible. It seems the lowest bufferlength accepted is .1s. Is there any way to get it less than that? My JS is below:
playerInstance.setup({
file: "rtmp://[ip]:1935/live/1",
primary: "html5",
skin: {
rtmp: {bufferlength: .1},
controls: true
3 Community Answers
Alex
JW Player Support Agent
0 rated :
Hi, there.
Our lowest bufferlength value available is 0.1. What are the issues that you are experiencing that would make you want to lower the buffer even more?
Thank you.
dan
User
0 rated :
Hi Alex,
Thank you for getting back to me. My goal is to decrease the latency of the player as much as possible. I've been able to lower the latency with another player with the same feed to about .8-.9s. JWPlayer is giving me a latency of about 1.2s. Is there any way to decrease the latency even further?
Alex
0 rated :
Hi, Dan.
The lowest buffer length that our player supports is 0.1.
Thank you!
