Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
JW player + visual studio 2013
Hello
A quistion.
I'm making for a older woman a programm in visual studio 2013 where she can look to a streaming video that brodcast bij her religion.
She can not press the smal buttons on the screen with the mouse.
So mij programm have bigger buttons.
On of the buttons will be FULL SCREEN.
I have read that this is the F button on the keyboard.
Bud this is not working?
Ma quision:
Does someone know how to make FULL SCREEN working in Visual Studio?
Or ken someone tell me why the F button is not working to make JW Player working full schreen.
Thanks,
JTvD
7 Community Answers
Randy
JW Player Support Agent
0 rated :
Hello,
You are correct, the F button will turn on/off the fullscreen feature. Please not however if you have controls turned off the keyboard shortcuts will not work.
Randy
jtvd
User
0 rated :
Hello Randy
How can i set the control buttons on in jw player.
When i press the F button nothing happends.
Regards JTvD
Randy
0 rated :
Hello,
The controlbar is on by default are you referring to having them display all the time or is there some other method you are trying to implement?
Thank you,
Randy
jtvd
User
0 rated :
Hello
No, I open JwPLAYER in visual studio 2013 in a Form and press the F key.
Now JW Playen should go into full screen filling.
But nothing happens.
Regards
Tinus
Randy
0 rated :
Hello Tinus,
If you try the implementation on a standard HTML page does the behavior replicate?
Randy
jtvd
User
0 rated :
Hello Randi
When i open JW player in explorer 11 then the F key works.
Bud in my program in visual studio 2013 not..?
Tinus
Randy
0 rated :
Hello Tinus,
This can be very difficult to troubleshoot as you might have some custom code that could be in place that we cannot see. If you prefer, you can email: support@jwplayer.com with a sample of the page so we can investigate further.
Randy
