JW7 plugin loading in flash mode
JW7 in flash mode is loading JavaScript and flash both versions of plugin. It seems a bug to me since JW7 doesn't support flash plugins, it should not load them in first place. Only JavaScript plugin should be loaded. Both plugins should not be loaded at all in any case. Now my legacy code is broken by this update and I need to add a unnecessary fix to flash plugin to detect version and don't do anything if player version is 7.
Is this a planned feature because I could not find any related documentation or a note that all users need to update their legacy code?
All I can find that in flash mode JW7 renders only video in flash through media Provider and video player itself is in html5. Only JS plugins are supported.
Thanks in advance
