JW7 Wowza DVR Streaming through Cloudfront - Can't get DVR to work.
I'm sending a live nDVR stream through wowza and while I can get the stream with full DVR functionality when I set the source file using the Wowza url but whenever I try to use the cloudfront url to the stream I can only see the live stream. No DVR.
I've checked using Wowza's test players and can get the DVR stream using their silverlight player (although it only seems to seek back to when I started viewing the stream, not all the way to when the stream began).
I'm using Self hosted JW7.0.1, with a Premium license, and trying to use HLS for the multiplatform support.
I've already contacted Wowza support on this and couldn't figure out the issue so I'm wondering if it might be a problem with JWplayer.
Wowza support mentioned that most query variables aren't supported when doing streaming through Cloudfront, but they did say that the "DVR" variable should be working.
Is there a way to get this to work? If so, I'd love to see an example.
