Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
On Click not loading rtmp stream
<a href="#" onclick="jwplayer('VideoPlayer').load({file:'video.mp4',provider: 'rtmp',streamer:'rtmp://10.10.1.1/vod'}).play();">Title</a>
This use to work on jwplayer 6 and every other version. Version 7 isnt working.
Ive tried
<a href="#" onclick="playerInstance.load({file:'video.mp4',provider: 'rtmp',streamer:'rtmp://10.10.1.1/vod'}).play();">Title</a>
and many other ways to load the video, Ive changed the video embed to
<div id='VideoPlayer'>Loading the player ...</div>
<script type='text/javascript'>
var playerInstance = jwplayer('VideoPlayer');
playerInstance.setup({
file: 'rtmp://10.10.1.1/vod/mp4:video.mp4',
image: 'http://10.10.1.1/jwplayer7/video.jpg',
</script>
The RTMP is working, the player loads the default video, but when I click my linked video I get: Error loading media: File could not be played.
<a href="#" onclick='playerInstance.play()'>Toggle playback</a> does work, it allows the player to play a video with an external link.
I know the player is setup correctly and that the external play button will work. I also know the RTMP streaming is working correctly. I just dont know if my video is being loaded, or do I need to change the provider terminology.
Any help would be greatly appreciated.
Thanks
7 Community Answers
Alex
JW Player Support Agent
0 rated :
Hi, there!
Can you please give me a link to a page where you have the affected player installed?
Thanks!
jherrieven
User
0 rated :
Try formatting your configuration as per the working setup - specifically include the streamer application and video file details in a single "file" parameter:
<a href="#" onclick="jwplayer('VideoPlayer').load({file:'rtmp://10.10.1.1/vod/mp4:video.mp4',type: 'rtmp'}).play();">Title</a>
"provider" should be switched to be "type" (although it shouldn't really be needed as the URL indicates it is an RTMP source)
James Herrieven
Powered by Haiku
http://powered-by-haiku.co.uk/
Tatami for Online Video
http://dev.powered-by-haiku.co.uk/solutions/tatami/
skype: JamesHerrieven
email: james[at]haiku[dot]co[dot]uk
dtrevino15
User
0 rated :
Figured it out finally. Had to change a bunch of stuff, and a library of over 1000 videos, I will have to do some fancy foot work.
My configuration is embedded into SharePoint. A simple list just gets filled out with the video title, application or location and folder. You can also add a thumb, and running time and SharePoint does the reset. Pretty cool for a Video Library.
Hope this helps someone else.
file: 'rtmp://10.10.1.1/VOD/mp4:Video.mp4',
image: 'Video.jpg',
title: 'My Cool Video',
primary: 'flash',
rtmp: {
bufferlength: 10,
subscribe: true,
skin: {
width: 640,
height: 480,
</script>
<script>
function loadVideo(myFile,myImage) {
playerInstance.load([{
file: myFile,
image: myImage
playerInstance.play();
</script>
<li><a href="javascript:loadVideo('rtmp://10.10.1.1/VOD/mp4:Video 2.mp4','image1.jpg')">Video 2</a></li>
<li><a href="javascript:loadVideo('rtmp://10.10.1.1/VOD/mp4:Video 3.mp4','image2.jpg')">Video 3</a></li>
dtrevino15
User
0 rated :
image: 'Video.jpg',
primary: 'flash',
rtmp: {
bufferlength: 10,
subscribe: true,
skin: {
width: 640,
height: 480,
</script>
<script>
file: myFile,
image: myImage
</script>
dtrevino15
User
0 rated :
image: 'Video.jpg',
primary: 'flash',
rtmp: {
bufferlength: 10,
subscribe: true,
skin: {
width: 640,
height: 480,
</script>
<script>
file: myFile,
image: myImage
</script>
dtrevino15
User
0 rated :
image: 'Video.jpg',
primary: 'flash',
rtmp: {
bufferlength: 10,
subscribe: true,
skin: {
width: 640,
height: 480,
</script>
<script>
file: myFile,
image: myImage
</script>
Alex
0 rated :
Great to hear you got it resolved!
Thank you!
