HLS Starting File / Quality
Hello,
is it possible to set the starting file or quality from a m3u8 list?
Right now the streaming starts with the lowest quality -which is visually annoying- no matter its position in the m3u8 and the streaming works its way up to the best matching quality.
Or is this a directive in the m3u8 file? Or does it need to be set server side?
