JW Player 7 Plugin for WordPress?
Hi all,
Wondering when there will be a JW Player 7 Plugin for WordPress? Thus far, can only find a JW6 version. If not, can I still embed JW7 videos into Wordpress?
Thanks! Sara
Hi all,
Thanks! Sara
I have the exact same question. Currently have the JW Player 6 plug-in v2.1.14. Is that already compatible with JW Player 7?
I will get an answer from our engineers and get back to you both.
Eagerly waiting for the wordpress plugin for jw player 7.
We do not support JW Player 7 in our WordPress plugin at present. Please stay tuned as we are working on an update.
While we are waiting for an update, your best option to embed a JW 7 player in WordPress would be to enter the Javascript embed code from your account dashboard directly into Text mode of a post.
Please! Something new for us to use the JW7 in Wordpress. Already embed directly in the text and not working.
Can you send me a link to a page where the direct Javascript embed is not working? Did you disable your JW 6 WordPress plugin? You will need to do that so the plugin does not interfere with your direct embed.
OK thank you! My movies again, but Youtube movies incorporated by JW Wordpress Plugin no longer work and have more than 150 films in this situation. It is no longer possible to use this feature?
As far as I know, YouTube URLs should be working as well. Can you send me a code example that is not working for you?
The embed Youtube is working, but not within the JWPlayer with my ad pre rool. http://ht.ly/QIaDF
I see your shortcode directly in the text on the page, but I do not see where our cloud-hosted player is loading. If you disabled our plugin, you will not be able to use the shortcode. You will need the full Javascript embed method as documented at http://support.jwplayer.com/customer/portal/articles/1406723-mp4-video-embed
Sorry, but the images within the time my ad pre rool not appear. What am I doing wrong? Can you help me? Once again! Please!!! http://ht.ly/QJG4r
WordPress has a nasty habit of converting ampersands (&) in ad tags to their HTML character code cousins (&). Unfortunately this completely breaks the ad tag.
My suggestion is to install the Raw HTML plugin and then check all the boxes in their little box to suppress this behavior in WordPress. After you install their plugin, you should see a little box in the right hand column of the page when you are creating / editing a post.
Sorry for not returning skillfully.
But when I enable the Vast Pre Roll, the embedded Youtube video does not display, the clock is running. Even after installing the Raw HTML plugin.
Hi i found this jwplayer 7 for wordpress in codecanyon
http://codecanyon.net/item/jwplayer-7-for-wordpress/12841912
i work with it it's amazing !
Are there any updates on when JW 7 is going to be released for Wordpress? Is the link above trusted?
Could we get an update about the progress of the WordPress plugin?
any word on JW 7 word-press plugin
JW7 for Wordpress is available but poor documentation on embed codes / shortcodes and don't get replies from support. Have gone back to FVplayer until it's sorted.
