Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
How build flash plugin with dynamic content
Hi,
I need get some data from remote server and display it one on jwplayer.
Example: I want change weather if it changed.
That as http://www.pluginsbyethan.com/newsticker6.html but I need to change description if it changed on the server.
Thanks.
1 Community Answers
Randy
JW Player Support Agent
0 rated :
Hello,
You may potentially want to look into our player API for more detail: http://support.jwplayer.com/customer/portal/articles/1413089-javascript-api-reference . You could pull data from the source server and have it fill in the bottom portion of the player.
Kindly,
Randy Le’Moine, Web Support Engineer, JW Player
www.jwplayer.com
