less than IE9 my video not playing
Here is my link
http://content.jwplatform.com/players/v9mslU17-iHTMCG4Z.html
to reproduce issue go to Internet Options --> Advance tab --> Disable "Enable Native XMLHttp Support"
Thanks in advance.
Here is my link
Thanks in advance.
Any updates????
I’m not sure how this setting has to do with IE8 support. Can you try to disable hardware acceleration and see if that video works?
Cooper
it is not working after disabling the hardware acceleration.
I m getting has "Error loading playlist:
Error loading file" . Please suggest soon ..
I’ve never seen or heard of this issue before. It sounds like this is isolated to your environment.
Cooper
could you help me to resolve this issue?
Can you please reset your browser settings and try again-
Cooper
not possible to reset browser settings..
Can you try updating your version of Flash? We haven’t had any reports of IE8 not working -
Are you able to play the video on our homepage: http://www.jwplayer.com/
-Cooper
Yes Video is playing in IE 8 : http://www.jwplayer.com/
I unchecked the option (as mentioned in first post) IE8 still your home page video is playing.
I need the same functionality.. can you please post the code for the same.
Mukesh,
The code is just a simple player embed:
jwplayer(“player”).setup({
file: ‘video.mp4’,
title: ‘Title’,
image: ‘poster.jpg’,
width:‘100%’
Best Regards,
Cooper
