Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Problem with playlist at Wordpress updating
Hi,
I use the plugin JW Player for Wordpress. I inserted playlists. It worked perfectly until I updated Wordpress recently.
Now, in my article, There still is the shortcode:
[jwplayer config="Player playlist 3 titres-16-9" playlistid="398"]
But, it displays: [PLAYLIST not found]
I tried to recreate a playlist, but it's still the same problem.
Address of a page for example:
http://www.artistesetassocies.org/claudio-parmiggiani-2/
On the other hand, if I insert just one video with the player, it works. The problem is just with the playlists.
Thanks for your help
Muriel
2 Community Answers
Cooper Reid
JW Player Support Agent
0 rated :
Hi Muriel,
I don’t see a player or player code anywhere within that page you sent -
Best Regards,
Cooper
romero.muriel
User
0 rated :
I don't understand. I already had this answer on the plugin forum. But yet, the shortcode is inserted in my article.
I don't know what to do...
I think I'm going to look for another solution;
Thanks
