Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Audio Sync is out on Firefox
Firefox seems to be the only browser with this condition -
http://goo.gl/jr7a4I
Then click on Blue Bloods / In The Box
Video plays fine everywhere else, but for what ever reason, Firefox 38.0 plays it out of sync.
Thanks for any help in advance!
5 Community Answers
Carolyn Ganon
JW Player Support Agent
0 rated :
Hi,
There seems to be some issues with your files themselves. This is the file that you have set: http://wac.c20c.edgecastcdn.net/00C20C/FTP_videos02-19-2014/ChicagoFire-KeepYourMouthShut.mp4
but it gives a 404 error and isn’t working on any browser.
What is the link to the page that is breaking on Firefox?
Thanks,
Carolyn
scottespenshade
User
0 rated :
Hi,
I fixed the old link with a process of elimination
Here is the issue recreated:
http://hollydaledirector.com/outofsync.php
PW: sync
Only seems to be happening on Firefox.
Carolyn Ganon
0 rated :
Hi,
Thanks for providing a new link. It appears to be an issue with the codec of your MP4 file. I set the primary mode to flash and it breaks in Chrome and Safari as well. Therefore, this isn’t just a browser compatibility issue.
Here is the breakdown of your file:
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from ‘http://wac.C20C.edgecastcdn.net/00C20C/FTP_videos02-19-2014/Blue_Bloods-InTheBox.mp4’:
Metadata:
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
creation_time : 2015-02-23 10:18:27
encoder : Lavf54.6.100
Duration: 00:39:54.31, start: 0.000000, bitrate: 602 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0×31637661), yuv420p, 720×404, 501 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc (default)
Metadata:
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (LC) (mp4a / 0×6134706D), 48000 Hz, stereo, fltp, 95 kb/s (default)
Metadata:
handler_name : SoundHandler
I would suggest re-transcoding the file to see if this fixes the issue. Here is a valid mp4 file that works in HTML5 and flash if you need one for testing purposes: http://qa.jwplayer.com/support-demos/static/bunny.mp4
Hope this helps! Let me know if you have any more questions.
Best,
Carolyn Ganon
Customer Support Engineer
JW Player
scottespenshade
User
0 rated :
Hi Carolyn,
Thanks so much of your time and efforts :)
I know very little about encoding. I get the videos from an editor and post them to the site. They usually work perfectly. Once in a while I have this same issue with Firefox.
Could you give me the encoding settings used on the bunny.mp4 file so I can pass it along to my editor?
Thanks Again!!
Carolyn Ganon
0 rated :
Absolutely! Here’s the breakdown of our bunny video:
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from ‘http://qa.jwplayer.com/support-demos/static/bunny.mp4’:
Metadata:
major_brand : isom
minor_version : 1
creation_time : 2008-11-26 13:45:10
Duration: 00:00:33.04, start: 0.000000, bitrate: 1235 kb/s
Stream #0:0(und): Video: h264 (Constrained Baseline) (avc1 / 0×31637661), yuv420p, 720×406 [SAR 1:1 DAR 360:203], 1169 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc (default)
Metadata:
creation_time : 1970-01-01 00:00:00
Stream #0:1(und): Audio: aac (LC) (mp4a / 0×6134706D), 44100 Hz, stereo, fltp, 83 kb/s (default)
Metadata:
handler_name : GPAC ISO Audio Handler
Hope this helps!
