Was there a WMV JW player that went away?
I have a site where I am using JW Player, and I need to play some older .wmv files. Obviously, they don't play with the default JW Player. In looking around the support area here, I've come across the same response in multiple posts (as recently as 4/2014) that points to this link:
http://www.longtailvideo.com/players/jw-wmv-player
However, that link just redirects to www.jwplayer.com. I see other posts that say you simply can't play wmv files with JW Player at all, and that video files have to be converted. I've also seen other posts around the internets that refer to a JW WMV player that uses/d Silverlight, but again, no dice. Did there used to be a supported WMV player that went away?
Thanks.
