Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
I can not get events for live streaming
Hello, I am using jwplayer to show a live streaming video with rtmp.
When the user broadcasting finishes his transmission I want the jwplayer to detect this event
and reload the page.
How can I do it?
I am trying
events:
onComplete:function()
alert('onComplete');
but it is not working.
It works with youtube videos.
5 Community Answers
Andrew
JW Player Support Agent
0 rated :
I’m not certain that we will fire a complete event when a livestream finishes. Offhand, is onError firing instead? My hunch is that if the stream ends, the player will fail to play it, resulting in an error event, rather than a complete event.
edgarpeixoto_06
User
0 rated :
onError does not work either. =[
Andrew
0 rated :
To be clear, what is happening when the stream ends? Is it also possible to do something with our buffer API section?
http://support.jwplayer.com/customer/portal/articles/1413089-javascript-api-reference#buffer
edgarpeixoto_06
User
0 rated :
When the stream ends the users who was watching the live event see this:
http://postimg.org/image/a2izkqigv/
onBufferChange event does not work. To tell the truth none of the events work.
Andrew
0 rated :
In that case, will onBuffer return the buffer value as the stream ends? For instance 0 once the stream fully stops broadcasting?
