Crossdomain issue - m3u8 through https
Hi JW,
I'm trying to play HLS stream with AES-128 it works fine on iOS, but not on flash. I tested it using hls-tester.
here a stream url: https://svpsecurehdvod-vh.akamaihd.net/i/2015/03/20150331_551a7977d4e2a_vg01/,240_160_64,320_180_250,480_270_500,640_360_800,960_540_1500,1280_720_3500,.mp4.csmil/master.m3u8?hdnea=st%3D1427897695~exp%3D1428502495~acl%3D%2Fi%2F2015%2F03%2F20150331_551a7977d4e2a_vg01%2F%2C240_160_64%2C320_180_250%2C480_270_500%2C640_360_800%2C960_540_1500%2C1280_720_3500%2C.mp4.csmil%2F*~hmac%3Da29d23f40d4ef7cec0752ccbb834febe200dcb7846667ce9e10018e8e12749a4
(with akamai token generated for 1 week) - stream unfortunately is geoblocked - but I can whitelist your IP if you need.
When I'm trying to play it on flash player it gives me an error:
"crossdomain access denied"
The issue is - crossdomain is there:
https://svpsecurehdvod-vh.akamaihd.net/crossdomain.xml
with body:
<?xml version="1.0"?><!DOCTYPE cross-domain-policy SYSTEM "http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd"><cross-domain-policy><allow-access-from domain="*"/><allow-http-request-headers-from domain="*" headers="*"/></cross-domain-policy>
and I see player is requesting it properly with HTTP 200 response from server:
https://slack-files.com/T0356Q2CJ-F048APEH9-a1c2c8a853
We could use of course Akamai HDCore plugin and play streams through HDS but since JW supports AES-128 from 6.12 version we don't want to add another plug ins if its not necessary.
all normal HLS streams from Akamai through HTTP are working without any issue.
Thanks for help
Konrad Pietrzkiewicz
VGTV
