Skin and Player Versions
When designing a custom skin, what version is acceptable if I have JW Player 6.12, 6.11, 6.10, 6.9? The reason why I have multiple versions is because there are some applications that optimally run when using JWPlayer self-hosted. My custom skin is <code>target="6.9"</code> which I never had problems with before, but now I'm getting the following error:
<blockquote><code>
Error loading skin:
Incompatible player version
</code></blockquote>
This happens at random times with different users on a set of random videos then they function again!
Before you ask for a link, my site is for exclusive access by subscription, so I can only give access to a JW technician.
