Cannot load M3U8: unsupported byte range
I have a test HLS video that I'm trying to play with Flash. Safari's native HLS support works fine, but JWPlayer's Flash gives the error "Cannot load M3U8: unsupported byte range". The playlist is https://dj91jaqtu6rt8.cloudfront.net/videos/bbb_sunflower_2160p_30fps_normal/playlist.m3u8 . The video was produced using Elastic Transcoder with presets very close to the builtins, except that the max frame rate is 30 fps.
