Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Hot add vast in jwplayer
I have third party VAST url and i tried to pass as "tag" but it's not working. following is my code:
advertising: {
client: 'vast',
tag: 'http://vpc.altitude­arena.com/vpc.xml?uid=8f39906e6914b055&page_url=[REPLACE]&cb=[REPLACE]&ref_page_url=[REPLACE]&player_width=[REPLACE]&player_height=[REPLACE]&video_duration=[REPLACE]&media_file_url=[REPLACE]&media_file_title=[REPLACE]&media_description=[REPLACE]&media_file_id=[REPLACE]'
3 Community Answers
Cooper Reid
JW Player Support Agent
1 rated :
Hi -
You will need to replace those [REPLACE] placeholders with our ad tag variables. This should do the trick:
http://support.jwplayer.com/customer/portal/articles/1434340-ad-tag-variables
-Cooper
mbarnhill
User
0 rated :
Hi,
Please can you be more specific about "our ad tag variables" how can i find that variable? is it video_key?
Cooper Reid
0 rated :
You can use any of the ad tag variables listed on that page. I’m not sure what values you should be using, that question would be for your ad network. Basically, the ad tag variables will replace with a dynamic value when the request to the ad network is made.
-Cooper
