Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
resize() not working with percentage
when I input percentage as parameters, like
jwplayer().resize(50%,50%)
I get a javascript error: Uncaught SyntaxError: Unexpected token ,
What did I do wrong?
3 Community Answers
jherrieven
Best Answer
Try enclosing your percent values in quotes:
jwplayer().resize('50%','50%')
View in conversation
jherrieven
Best Answer  User
0 rated :
Andrew
JW Player Support Agent
0 rated :
Additionally, I don’t believe you’re going to be able to set a percentage for both height and width here. You can use (‘50%’, 500) or something similar, however.
jherrieven
User
0 rated :
You can use percentage for both width and height provided the players parent container inherits, or has an explicit, width and height.
James Herrieven
