Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
m3u8 cannot be played. please help
I used aws elastic transcoder to transcode an mov to hls. the link is below. it doesn't play. error message: "Playlist could not be loaded. No playable sources found." Please help!! Thank you.
<div id='player20V2HW9G'></div>
<script type='text/javascript'>
jwplayer('player20V2HW9G').setup({
file: 'https://s3.amazonaws.com/sproutup-test-cdn-hls/test/house-video.m3u8',
width: '60%',
aspectratio: '16:9'
</script>
1 Community Answers
Todd
JW Player Support Agent
0 rated :
I’m getting an Access Denied error when I try to load your M3U8 stream directly in my browser. Are the file permissions set correctly on your side?
