Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Again, same problem , not solved! GOOGIMA error on load
your answer for this link,
http://support.jwplayer.com/customer/portal/questions/8444816-6-1-error-on-load-javascript
Not solved my problem. My whole code stops working when I try to use any new version of jw player, it does not happen in version 6.8. When I try to upgrade to 6.11, the same error happens, and all my scripts, stop, you will solve this or not?
I am to renew the license and this information is crucial for me to renew or not.
page running ok with t 6.8 jw
http://www.apparitionstv.net/jwerror/
same error page with jw 6:11
http://www.apparitionstv.net/jwerror//jwerror/
or you guys tell me what to do in the code to fix, or remove this bug the code, that this disturbing me, help me! I Need an urgent solution
6 Community Answers
kristiano
User
1 rated :
ops, here is the right links
on error
working
Andrew
JW Player Support Agent
-1 rated :
Hi. The functional page shows:
http://revelmedia.trafficmanager.net/vod/client1/ApparitionsTV-Sunday-1-2-2015_360p.mp4/playlist.m3u8
The nonfunctional page shows:
http://revelmedia.trafficmanager.net/vod/definst_/smil:prometheus-tlrgh1080p/playlist.m3u8?nimblesessionid=382964
Which is providing a 404 error, which is why the page is not working.
kristiano
User
0 rated :
exactly friend, you do not understand? the call load playlist of javascript give a error and not load the playlist, so it appears that video of Prometheus.
Check with the Chrome tools that you will see the error, please
Andrew
0 rated :
The error is happening because your M3U8:
Does not exist and is giving a 404 error.
Directly accessing this file is yielding a 404 error in my console. This means that it is not accessible from your website. The other M3U8 does exist, which is why it works with 6.8.
jherrieven
User
0 rated :
@kristiano
This problem comes about because you are trying to load a new playlist before the original setup has been finalised.
Try wrapping this line:
jwplayer('player').load(myPlaylist.slice(0, 8))
In the "onReady" event listener as follows:
jwplayer('player').onReady(function(){
jwplayer('player').load(myPlaylist.slice(0, 8));
That should resolve the issue.
James Herrieven
kristiano
User
0 rated :
thanks James, finally a smart person !!! The support of JW is stupíd,
