VMAP Code For Multiple Ads
I wanted to obtain the Jwplayer VMAP coding for multiple ads to display with preroll and (3) midrolls with time stamps of 5, 10, 15, 20, 25, 30, 35, 40
I am trying to have increase our content revenue with vast tags we have from ad platforms
You can configure your own VMAP according to our page here:
http://support.jwplayer.com/customer/portal/articles/1432026-vmap-ad-schedule
We do not currently provide these VMAP files, however. They should be configured on your end according to what you require.
<vmap:VMAP xmlns:vmap="http://www.iab.net/vmap-1.0" version="1.0"> <vmap:AdBreak breakType="linear" breakId="85cac7e0fbad11e3b283fbde008b4e10" timeOffset="start"> <vmap:AdSource allowMultipleAds="true" followRedirects="true" id="1"> <vmap:AdTagURI templateType="vast3">
<![CDATA[
http://vast.yashi.com/5004&vid_id=YOUR_VIDEO_ID&vid_title=BawnTv
http://v.admedia.com/?id=ODwqOSY&page_url=http%3A%2F%2Fwww.bawn.tv%2F&autoplay=1&content=6&title=BawnTv&video_id=[VIDEO_ID]
http://u-ads.adap.tv/a/h/dyAjnKmo8s4rb3k1UjJSRA==?cb={cachebreaker}&pageUrl=http%3A%2F%2Fbawn.tv&context=pubid%3Dbawntvus&eov=eov
</vmap:AdTagURI> </vmap:AdSource> </vmap:AdBreak> <vmap:AdBreak breakType="linear" breakId="85cac7e0fbad11e3b283fbde008b4e10" timeOffset="00:05:00"> <vmap:AdSource allowMultipleAds="true" followRedirects="true" id="1"> <vmap:AdTagURI templateType="vast3">
<![CDATA[
</vmap:AdTagURI> </vmap:AdSource> </vmap:AdBreak> <vmap:AdBreak breakType="linear" breakId="85cac7e0fbad11e3b283fbde008b4e10" timeOffset="00:20:00"> <vmap:AdSource allowMultipleAds="true" followRedirects="true" id="1"> <vmap:AdTagURI templateType="vast3">
<![CDATA[
<![CDATA[
</vmap:AdTagURI> </vmap:AdSource> </vmap:AdBreak> <vmap:AdBreak breakType="linear" breakId="85cac7e0fbad11e3b283fbde008b4e10" timeOffset="end"> <vmap:AdSource allowMultipleAds="true" followRedirects="true" id="1"> <vmap:AdTagURI templateType="vast3">
<![CDATA[
</vmap:AdTagURI> </vmap:AdSource> </vmap:AdBreak> </vmap:VMAP>
This is a sample which is different from the one listed on
I’m a bit unclear here. Is the above tag not working? If not, can you provide a link to a page where you’re using this?
It work but what i am asking is that during the midroll section we like two or three ads to play during the midroll and pre-roll
http://www.bawn.tv/myrtlemejay
You can create an ad pod to load in a particular ad slot, though there may be issues using VPAID ads in this scenario. We’d suggest using an HTML5 compatible ad tag with the player if possible.
So what should i do from here? Because I would like to have those tags to display. Therefore i would have have so many breaks if we can have only a few breaks within the content
You can use separate VPAID files throughout the VMAP that are not being called from an ad pod. For example, using a particular VPAID ad at 5 second, another at 6. This wouldn’t be an ad pod specifically, but it would behave similarly.
So within the code how that that appear? And also would the VPAID file be the "xml" or another file type?
The VMAP would indeed be an XML file. To do this, you’d need to set the timeOffset to be a second or two apart, depending on when you wished an ad to display. Again, you wouldn’t be able to chain ads together in an ad pod-esque way, but this would be a workaround for now.
