Create a Control bar for a JW player
I have four JW players on a single screen and I am playing the same Video in all the players but video is captured from different angles and I am handling all from a single control bar and I have also implemented the timeline intraction in that all is working fine all videos are playing at same time but I need to put that control bar at the bottom of all currently it is attached with the first player .
I have a square area and have 4 players in 2 lines means 2 in first line and other 2 in second so I need to put that control bar in the last of the square is it possible if yes the please help me..?
Thanks in advanced..
Regards
Gurpinder
