HLS stream works fine in html5 mode but not in the flash mode
Our backend works with videos that have already been split into chunks. We process each of those chunks with ffmpeg to produce different bitrate streams and then stream them via HLS. Streams that we created with some certain ffmpeg params work fine - videos are played nicely. But for other sets of ffmpeg params we encountered a problem - JwPlayer plays fine in html5 mode, but glitches in flash mode (it skips parts of the video). We checked a number of other flash players and they seem to work fine with those videos. We can`t figure out what seems to be the problem with flash version of JwPlayer.
The example of our stream that works fine in both html5 and flash modes: http://dev-api.pov.la/api/video/sC3/6y4kehK/playlist.m3u8
This video was encoded with the following ffmpeg params:
-acodec copy -vcodec libx264 -copyts -mpegts_copyts 1 -vf "scale=480:-1, fps=30000/1001" -vb 200000 [path].ts
The example of our stream that works fine only in html5 mode: http://dev-api.pov.la/api/video/aC3/6y4kehK/playlist.m3u8
You can see that video plays fine up to a beginning of a 4th second, and then jumps on the 8th second.
FFmpeg params for this video:
-acodec libvo_aacenc -ab 32k -ac 1 -vcodec libx264 -copyts -mpegts_copyts 1 -vf "scale=320:-1, fps=10000/1001" -vb 55000 -bf 0 [path].ts
Can you please point out, what is wrong with our stream?
