Name is required.
Email address is required.
Invalid email address
Answer is required.
Exceeding max length of 5KB
Is it possible to load a player with no initial video?
We are looking to replace our existing video player in our e-learning templates.
One template has a video player and several options for a user to click, clicking a link plays a video. This part is obviously possible using the playlist functionality.
The problem is we don't want a default video loading, it is up to the user to select one.
The only way I could think to get around this is to have a blank video/loading image and use that to initialise the player?
Many thanks,
Paul.
3 Community Answers
Cooper Reid
JW Player Support Agent
1 rated :
Hi Paul,
Yes, you must provide a blank.mp4 video, as the player cannot be loaded without the `file` parameter.
Best Regards,
Cooper
paul.solecki
User
0 rated :
Hi Cooper,
Many thanks! That's no problem :)
You can close it off now.
Thanks,
Paul.
Cooper Reid
0 rated :
No problem-
Cooper
